Hello, We had the same problem (we use Crystal XI). What I did was
when creating the report within the "Data Expert" I select "Create New
Connection" then "ODBC(RDO)"
This brings up a screen where I select "Enter Connection String"
I then enter
Driver=Data Direct 4.20 32-BIT OpenEdge SQL v10.0B; DB=mfgsys80;
PORT=8050; HOST=xxxxx; UserID=xxxxx; PW=xxxxx;CMT=2
We had created a user for accessing the database called ODBCUser which
I used for the UID.
Hope this helps.
djj
I then enter
I used for the UID.
Hope this helps.
djj
