Hello everyone, I really need some help our guidance here.
I have a custom which uses a custom DLL working perfectly. no problems with that. this custom reads an xml file and writes some info into UD fields inside the APInvoiceEntry/Header/MischCharges… this is perfect.
Now I was requested to create a “new” custom, using the same DLL file but instead of “writing” in APInvoiceEntry/Header/MischCharges, the info will be placed directly in the Header/Detail tab… process runs smoothly until the custom DLL is called. I´m receiving the following error message.
CS0103 - line 746 (2730) - The name ‘ValidarXML’ does not exist in the current context
any gues or suggestion?
the code “calling” the custom DLL is exactly the same used in the “working” custom.
XmlNode root = xmlSoap.DocumentElement;
XmlDocument xmlResultado = new XmlDocument();
xmlResultado = ValidarXML.Servicio.CallWebService(xmlSoap);
