Custom Field: Sum of Product Shipped?
After some more research, it appears that in order to get this total, I need to create a calculation that multiplies the ship qty from the customer shipment by the unit price of that line on the sales order. For the sum of all items in this shipment, I would have to do this for each line.
In order to place this information on the Customer Shipment screen, I would need to add the appropriate Order tables and then create the custom calculation. I can conceptualize what needs to be done; however, am not familiar with the code/operations that need to be done to do this. Any suggestions are appreciated. Thank you.
--- In vantage@yahoogroups.com, "pbriscoe10" <pbriscoe10@...> wrote:
> Hello,
> I was wondering if I could get some help creating the following field: a user defined field (calculated) to appear on the Customer shipment screen that will populate with the total value of product being shipped. Any help is appreciated. Thank you.
Hello,
How do you make a created option field mandatory on a BAQ Report Paramter
Screen?
Thanks in advance
For simplicity's sake, Id just design the parameter into the crystal
report itself, if they don't fill out the parameter, they won't get any
data, that should make it fairly self fulfilling.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of advantage
Sent: Monday, November 30, 2009 8:21 AM
Subject: [Vantage] Make a field mandatory on a BAQ Report Parameter
Screen
Paramter
Screen?
Thanks in advance
Any ideas on this? Your help is appreciated. Thank you.
> Hello,
Ok, I have figured that no you cannot write a BPM on BAQ Report Parameter
screens. So I tried to shortcut it in the BAQReport Designer under the
options field default, I put "Job Required" then I wrote a customization on
the Report Parameter screen (PS: I'm not a coder by any means, so please
help:)
I was curious what is the code for it to look at that "Job Required" text in
ReportParam.Character01 and pop up a message box that tells the end user
"Job Required"....
I picked through the wizard Form Event Wizard Before Field Changes
I have this so far.
Private Sub BAQReportParam_BeforeFieldChange(ByVal sender As object, ByVal
args As DataColumnChangeEventArgs) Handles BAQReportParam_ColumnChanging
Select Case args.Column.ColumnName
Case "Character01"
Dim Message As String = "Job Number Required.Cancel this operation?"
Dim Caption As String = "Job Number Required"
Dim Buttons As Integer = MessageBoxButtons.YesNo
Dim Result As DialogResult
If (args.proposedvalue.ToString().Length > 13) Then
Result = messagebox.show(Message, Caption, MessageBoxButtons.YesNo, _
MessageBoxIcon.Question, MessageBoxDefaultButton.Button1, _
MessageBoxOptions.RightAlign)
End If
If Result = DialogResult.Yes Then
oTrans.Undo
Throw new UIException
End If
Thanks in advance
advantage
Sent: Monday, November 30, 2009 9:21 AM
Subject: [Vantage] Make a field mandatory on a BAQ Report Parameter Screen
Screen?
Thanks in advance
I think the potential trouble there is if they don't attempt to make any
changes at all? To be most reliable youd have to trigger off of an
attempt to print or preview... as to how to intercept an action from
the menu items or the buttons...im clueless..
Rob Bucek
FAX: (715)284-4084
Of advantage
Sent: Monday, November 30, 2009 2:53 PM
Subject: RE: [Vantage] Make a field mandatory on a BAQ Report Parameter
Screen
Parameter
on
help:)
text in
"Job Required"....
I have this so far.
ByVal
Case "Character01"
End If
oTrans.Undo
End If
Thanks in advance
Behalf Of
advantage
Screen
Paramter
Screen?
Thanks in advance
