Thanks Jose. Think maybe this is a bit beyond my capabilities as I am still not sure where exactly I should put the code, and also I am trying to authenticate the Employee and not the User :/
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Session _sess = new
> Session("user","password","AppServerDC://yourserver:8301",Licencing.Default)
> That will authenticate you.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Mon, Oct 1, 2012 at 11:23 AM, tracy.tmat <tracy.smith@...> wrote:
> > Maybe it's just been too much of a long day but it's how / where to
> > authenticate I can't get my head round... am I missing something really
> > obvious?!
> > Was wondering about having custom form that upon loading asks for a
> > Password (which could be coded into the form customisation?) and adding
> > this form to the relevant menu? Or am I trying to simplify something that
> > can't be done?
> > Thank you.
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > Kind of it a bit complex
> > > But you can put a Before Method call (like before Update)
> > > Where you write (by hand) a Form which has Username: Password: fields
> > then
> > > you use the Session to authenticate and you keep a List of Users
> > (possibly
> > > by Group Security) which can do QTY Adjustments if authentiation is
> > > successfull and the userid provided is in your list allow them to
> > proceed.
> > > Otherwise, cancel the request.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Mon, Oct 1, 2012 at 10:55 AM, tracy.tmat <tracy.smith@> wrote:
> > > > Finally got back round to this after being dragged onto other projects
> > and
> > > > have tried customising with a Password against the employee but Qty
> > > > Adjustment has no 'spare fields' for me to validate against.
> > > > Also as we are on Vantage 8 there is no option in the BPM for an input
> > box.
> > > > Is it possible to force a password onto a form customisation? Any
> > further
> > > > advice appreciated!
> > > > --- In vantage@yahoogroups.com, "Tom J. Christie" <tchristie@> wrote:
> > > > > We have actually implemented something on Inspection Processing to
> > > > identify the inspector. We are using MES stations and MES does not
> > record
> > > > who performed the inspection, just the name of the MES station...
> > > > > You need a combo box on the inventory adjustment screen that must be
> > > > populated to actually perform the transaction where they select the
> > user
> > > > and it triggers a BPM. My BPM calls a BPM form where they enter their
> > > > passcode. It confirms that the passcode matches the UD field on the
> > > > employee table where I store their code. I have customized the BPM
> > form to
> > > > display the entry field in pass code ******* style.
> > > > > Now, this works in Epicor 9.05.606B but I don't know what version you
> > > > are using and whether these tools are available so YMMV.
> > > > > Tom
> > > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > > > Behalf Of Dan Godfrey
> > > > > Sent: Tuesday, September 04, 2012 8:26 AM
> > > > > To: vantage@yahoogroups.com
> > > > > Subject: RE: [Vantage] Custom Form - Prompt for Password?
> > > > > Do you mean "none of the other users" as all but the Dispatchers or
> > > > everyone including the OTHER dispatchers then the one current
> > Dispatcher?
> > > > If all but dispatcher, then that is a good example for using the
> > Security
> > > > Ids. That will eliminate everyone not in a group.
> > > > > This might be a two part issue if it is the latter. Using the
> > Security
> > > > ID to block all non-Dispatchers, then code to block out the other
> > > > dispatchers. A quick thought of how to do it would be to set a
> > parameter in
> > > > some table when the first Dispatcher comes in. Check that value when
> > > > everyone comes in ( which would only be the Dispatcher since the
> > Security
> > > > ID blocks everyone else) and if it is set then pop up a pretty little
> > > > message saying that they lose and close the window for them, else set
> > the
> > > > value. Then obviously you would set the value back before you close the
> > > > window.
> > > > > This is just my thought, but I am sure the intelligent guys have some
> > > > cool trick.
> > > > > Dan
> > > > > -----Original Message-----
> > > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > [mailto:
> > > > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
> > Of
> > > > tracy.tmat
> > > > > Sent: Tuesday, September 04, 2012 3:18 AM
> > > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > > > Subject: [Vantage] Custom Form - Prompt for Password?
> > > > > OK, I know this is not how we should use Vantage properly but have to
> > > > ask! We have one log-on for our Despatch team and they each have
> > individual
> > > > Employee ID's for entering Kanban Receipts. All good!
> > > > > BUT we want one person to be able to use the Quantity Adjustment
> > screen
> > > > but none of the other users... is this best done by customising the
> > form?
> > > > Or would a BPM work? Any pointers on the code - I've tried searching
> > but
> > > > can't find anything :( We're on Vantage 8.03.409a - Thanks.
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > > have already linked your email address to a yahoo id to enable access.
> > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > > > and Crystal Reports and other 'goodies', please goto:
> > > > http://groups.yahoo.com/group/vantage/files/.<
> > > > http://groups.yahoo.com/group/vantage/files/>
> > > > > (2) To search through old msg's goto:
> > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > [Non-text portions of this message have been removed]
