Custom XML data
Perfect. Thank you!
--- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@...> wrote:
> You can use customization mainenance under the utilities to do this.
> Under actions you can export the xml.
> --- In vantage@yahoogroups.com, "sanfordm99" <sanfordm99@> wrote:
> > Hello,
> > I have a custom UD101 form. Recently the form started crashing ( I only made one change, so I think I can recover it). The problem is that it crashes Vantage (8.03.408B) completely before the form loads completely. Does anyone know where the custom xml data is stored so that I can manually fix the problem or at least copy the code from it to a new customization?
> > Thanks,
> > Mike
Hello,
Mike
--- In vantage@yahoogroups.com, "sanfordm99" <sanfordm99@...> wrote:
> Hello,
> Thanks,
> Mike
