Hi,
We are on v9.05.601b and are also seeing the Credit Hold flag set for no apparent reason error.
Epicor support wants us to run the Conversion 9527 periodically but that will leave us to find the incorrectly set Credit Hold flags and set/unset them manually.
Has anyone developed a better solution?
After spending some time with 2 diff Epicor reps I believe that the issue is not on their "to-do" list because it hasn't been effectively recreated.
Thank you,
Dave Beberman
Sr. Business Analyst
Ferguson Perforating
Providence RI
dbeberman@...
Thank you,
Dave Beberman
Providence RI
dbeberman@...
--- In vantage@yahoogroups.com, "Gerry Loranger" <gloranger@...> wrote:
> The Mass Credit Information Update command recalculates the current credit status for each customer. The credit check process is run against all the customers in your database. All changes that you made within the Customer Credit Manager will be applied to records throughout the application.
> This command ignores all customers who are manually placed on Credit Hold.
> All the customer, sales order, shipment, and AR invoice records are updated with the credit information you updated through the Customer Credit Manager
> Gerry
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chris Thompson
> Sent: Thursday, September 16, 2010 10:02 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Customer on Credit Hold for no reason
> Hi
> What exactly does the Mass Credit Information Update do?
> Thanks.
> From: Gerry Loranger <gloranger@... <mailto:gloranger%40preformed.on.ca> >
> Sent: Thu, 16 September, 2010 12:57:29
> Subject: RE: [Vantage] Customer on Credit Hold for no reason
> Perhaps the problem might be resolved if you open the Customer Credit Manager
> and click Actions > Mass Credit Information Update.
> Or you might try running conversion 9,527 â€" Set Credit Limit Totals.
> Gerry
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of
> Steven Gotschall
> Sent: Thursday, September 16, 2010 5:41 AM
> Its in a parent child relationship and the parent went on credit hold?
> An order was entered that put them over the credit limit and then the order was
> deleted?
> From: Chris Thompson <chriselectrix@... <mailto:chriselectrix%40ymail.com> <mailto:chriselectrix%40ymail.com>
> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> Sent: Thu, September 16, 2010 4:42:07 AM
> Subject: [Vantage] Customer on Credit Hold for no reason
> We regularly have an issue where our customers are put on credit hold for no
> reason. They still have plenty of credit remaining, but for some reason they are
> put on credit hold.
> Epicor allows us to process the order and doesnt put the customer on credit
> hold.
> When we come to pack/ship the order, the customer will get put on Credit Hold
> for no reason.
> Are any of you having a similar issue or do any of you know why this might be
> happening?
> We are on 9.04.505c (this issue used to happen on 503b too).
> Now on a monthly basis we have to go through each customer and take them off
> credit hold - which defeats the object of having the credit hold feature in the
> first place.
> We have found no links to determine a pattern when it happens - it is totally
> random.
