You could use a EpiCombo control. Check out the settings (properties) of the Attn control for the Shipto on the Sales Order Entry form. It shows how to set the EpiBOName, EpiColumns, And EpiFiltersAppend (of course you would have to change these to meet your needs). You can even add hidden columns so that you could pull additional field data using custom code.
Sent: Thu, June 17, 2010 9:57:47 AM
Subject: [Vantage] Customer Ship to Selection to UD form
Â
Right now I have a UD form where they can search and select a customer to tie to the record. Now there is a new requirment to be able to select a ship to also based on the customer they chose. Can anybody lead me in the correct path.
Â
