Currently on version 406A. Has anyone created custom code to run in the Quote Sales Order Wizard? I customized Quote Order Wizard by adding some additional date fields. The customized form is being called properly when you want to create a sales order from a quote, but now I want to create some custom code to populate date fields based on the order date and ship via fields. It appears the object method combination to call the wizard is Quote.CreateOrder, but while in customization mode it appears fields are tied to the OrderHed table. I don't think a record has been created in the OrderHed table at this point, so I'm not sure which fields to use in my code.
David Pfiester
NuStep, Inc.
734-769-3939 x150
David Pfiester
NuStep, Inc.
734-769-3939 x150
