I found my problem and feel a bit silly.
My customization is add the UD Table to RMADtl.
I picked a RMA without a detail line hence the error.
I apologize for any confusion.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cathy@...
Sent: Tuesday, April 22, 2014 12:11 PM
Subject: [Vantage] Customization - adding UD table with UltraGrid
I am forgetting about the drop down at this point because I can't even add a record to UD01.
I added UD01 to RMA Processing.
This is how I mapped the UD01 to the RMADtl.
parentKeyFields[0] = "PartNum";
childKeyFields[0] = "Key1";
parentKeyFields[1] = "RMANum";
childKeyFields[1] = "Key2";
parentKeyFields[2] = "RMALine";
childKeyFields[2] = "Key3";
parentKeyFields[3] = "CustNum";
childKeyFields[3] = "Key4";
Then I added a new sheet to RMA Processing sheetLinePanel.
The Epi Binding is UD01View.
Under File New UD01 - I get an error.
"************** Exception Text **************
System.IndexOutOfRangeException: Index -1 is either negative or above rows count."
Can I map a numeric field to the Key fields?
If not, since they are keys - what is the best way to map RMADtl to UD01?
Any help would be appreciated.
