Customization - how to deploy everywhere?
Environment
2023.1.7 (a.k.a. 11.2.300.0) On-prem, but no coding. Currently using Classic screens for everything.
Work so far
I have added a UD column to the InvcDtl table (InvcDtl.Note_c). Have added a tab to Invoice Entry so that the users can enter the required information.
I have created a menu item which will display this customized version of Invoice Entry that ultimately gets to the customized version of the form. All good there.
Question
How do I get the customized version of AR Invoice Entry to launch from the Add Credit Memo button in RMA processing? Tried to look at the properties of the existing button, but did not see anything.
Thanks.
—sam
If you go into Menu Maintenance, and then into the Processes item in the tree menu, you should find a “RMA Credit Memo” item. Open that up and you should be able to select your Customization.
Note that all normal Customizations are “deployed” via Menu Maintenance.
