Customization of Memo Entry
Dan,
You need to create the customization, then you need to go into process
calling maintenance and sub-process maintenance. Basically, you need to
create a menu item for it (sub-process maint) that tells it what
customization to use, and then process calling maint tells it to use that
menu item.
The actual way you run this may depend upon the version you're on. Search
the group for process calling maint and you should find detailed
instructions if needed.
Kevin Simon
SimsTrak Consulting
Dan Sirow
Sent: Friday, July 30, 2010 10:08 AM
Subject: [Vantage] Re: Customization of Memo Entry
But Memo Entry is not on a menu, it is launched from a button on the toolbar
- I know there is a way, but I forgot.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
Gomez <jose@...> wrote:
> Go to menu maintenance find the menu item, select customization
> Sincerely
> Jose C Gomez
> http://www.josecgomez.com
> On Fri, Jul 30, 2010 at 9:36 AM, Dan Sirow <dansirow@...> wrote:
> > I made some customizations of the Memo Entry Detail screen, but I forget
> > how make it the default of all users
I made some customizations of the Memo Entry Detail screen, but I forget how make it the default of all users
Sincerely
Jose C Gomez
But Memo Entry is not on a menu, it is launched from a button on the toolbar - I know there is a way, but I forgot.
> Sincerely
> Jose C Gomez
