Customization - Pasting overwrites existing text instead of moving it downward
I am sure there is an easy answer but I’ve noticed after the last update or 3 that when I paste text into my customization it overwrites existing text instead of pushing it down which I do not recall happening at my previous job.
Is this a setting or a bug? The text being replaced is not highlighted. If I paste into a blank line above or below it just overwrites existing code instead of moving the rows down like most other editors.
If I am moving around code to make it more efficient or elegant I have to put a bunch of blank lines in before pasting anything.
I am not using anything close to a most recent update, but did you by chance hit the “Insert” button? Let’s eliminate user error before going for the update :sweat_smile:
No matter the method of pasting that I try it does not work.
With Epicors context menu - Cut and Paste. CTRL V. Shift-INS it all ‘works’ the same thing. It overwrites the code that is on screen.
When I use the last 2 with any other program they work properly they move the text down and out of the way.
I can confirm this happens to me too, in Live and Pilot. I didn’t have time to report it when I first noticed, and now I just deal with it.
Yes! I do the same thing. After I realized what was happeneing, I started putting in a big chunk of empty space so that my pasted code wouldn’t overwrite what was there already. Strangely it overwrites, but keeps some of the brackets in place.
:thinking:
Correct and thanks for mentioning the brackets.
It does overwrite but it will keep code and brackets that it does not displace ending up with a weird hybrid of original and new code.
No help from me except to confirm the same thing. We just upgraded from 10 to the latest 11.2.400.6 so I can’t say when it broke but it is now. I just need to remember to insert a bunch of blank lines before I paste.
I’ve never encountered a similar pasting bug before. It’s weird.
Spoke with support on this and there is an open problem for this issue. No ETR yet.
PRB0274329
