My co-worked found this out:
In Epicor 9 we can access the tools on the toolbar:
Private Sub baseToolbarsManager_ToolClick(ByVal sender As Object, ByVal args As Infragistics.Win.UltraWinToolbars.ToolClickEventArgs)
Select Case (args.Tool.Key)
Case "ClearTool"
ClearNumericDisplayOnlyData()
Case Else
End Select
End Sub
Thanks for all the help!
Case "ClearTool"
Case Else
End Select
End Sub
--- In vantage@yahoogroups.com, "k_stump" <kristi.stump@...> wrote:
> Hi All,
> I am customizing Sales Order Entry with a numeric field that shows the order total without tax. I added a numeric field to the screen and did a calculation using values from epi data view. My field displays fine. But when I hit the clear button, my numeric field does not clear. I don't have it bound to anything since it is just a calculation. How do I tell when clear is hit ? I have run a Trace and don't see it there. I think if I know when clear is hit I can just move zeros to my field. Any suggestions? How do others do this?
> Thanks
> Kristi
