Customization to Toggle CallContextBpmData Cast Error
Hello,
I’ve added a button to the RFQ supplier screen and I’m trying to use it to toggle CallContextBpmData [“Checkbox01”], the 2 examples of code below compile fine but I’m getting the error “Specified cast is not valid” when I click the button, (I’ve restarted and cleared client cache)
Any help would be much appreciated
Example 1:
// Custom code for RFQForm
// Created: 7/09/2020 11:22:30 PM
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Contracts_BO_PartRevSearch;
extern alias Erp_Contracts_BO_Company;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.BO;
public class Script
		this.epiButtonC1_Add.Click += new System.EventHandler(this.epiButtonC1_Add_Click);
		this.epiButtonC1_Add.Click -= new System.EventHandler(this.epiButtonC1_Add_Click);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void epiButtonC1_Add_Click(object sender, System.EventArgs args)
	EpiDataView edvCallContextBpmData = ((EpiDataView)(this.oTrans.EpiDataViews["CallContextBpmData"]));
			System.Data.DataRow edvCallContextBpmDataRow = edvCallContextBpmData.CurrentDataRow;
			if ((edvCallContextBpmDataRow != null))
				edvCallContextBpmDataRow.BeginEdit();
				if ((bool)edvCallContextBpmDataRow["Checkbox01"] == true)
					edvCallContextBpmDataRow["Checkbox01"] = false;
				else
					edvCallContextBpmDataRow["Checkbox01"] = true;
				//edvCallContextBpmDataRow.RowMod = "U";
				//edvCallContextBpmDataRow.Update();
				//edvCallContextBpmDataRow["Checkbox01"] = !edvCallContextBpmDataRow["Checkbox01"];
				edvCallContextBpmDataRow.EndEdit();
				oTrans.Update();
Example 2:
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.BO;
public class Script
				edvCallContextBpmDataRow["Checkbox01"] = !(bool)edvCallContextBpmDataRow["Checkbox01"];
				oTrans.Update();
The full error message:
Application Error
Exception caught in: App.RFQEntry.RFQForm.EP.Customization.RFQEntry_TWG.CustomCode.0
Error Detail
Message: Specified cast is not valid.
Program: App.RFQEntry.RFQForm.EP.Customization.RFQEntry_TWG.CustomCode.0.dll
Method: epiButtonC1_Add_Click
Client Stack Trace
at Script.epiButtonC1_Add_Click(Object sender, EventArgs args)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at Infragistics.Win.Misc.UltraButtonBase.OnClick(EventArgs e)
at Ice.Lib.Framework.EpiButton.OnClick(EventArgs e)
at Infragistics.Win.Misc.UltraButton.OnMouseUp(MouseEventArgs e)
at Ice.Lib.Framework.EpiButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
It’s late, so I don’t see anything offhand. have you tried running it through Visual Studio to debug it?
EDIT: Actually I think the problem is with your conditional statement:
Example 1:
and Example 2:
edvCallContextBpmDataRow["Checkbox01"] = ! (bool)edvCallContextBpmDataRow["Checkbox01"];
I think the Checkbox01 can be nullable. So it won’t allow a casting of (bool)null.
ok, I got my code from here
I’ve since added a UD field and have now got that working as needed
thanks
I fixed the code on the original post. @Doug.C was right it needed a null check.
				if(edvCallContextBpmDataRow["Checkbox01"] == DBNull.Value)
				else
				oTrans.Update();
Thank you @Carson and @Doug.C
If I understand correctly, before the button is clicked for the first time the field value will be null, so when it is clicked for the first time the null check will set the field to true?? and subsequent clicks will change it between true and false
That’s correct.
