Customizations Not Taking Affect
Hi Brad,
> Yesterday, we made 2 fields in Sales Order Entry a mandatory field so that users cannot save a record without filling in these two fields. When we tested it, everything seem to work fine. However, on one computer, this change did not take affect. It works on the rest of the computers, except this one. Does anyone have any ideas?
Does the customization show up when using the main menu or is that
person starting the command using a short cut? If it works off the
menu then try deleting the short-cut and adding it again.
Mark W.
Did that user log out & back in? the customazations will not take effect until the user's next logon.
2 thing to try. First if they have that customization on the favorites, have them delete it from the favorites then log back in.
Also while out of Vantage delete the folder \Documents & Settings\All Users\Application Data\Epicor\Vantage\"Version"
Yes, they tried logging off and back on again. Thanks mmcwilliams, deleting
the "version" folder seemed to have fixed the problem. On a s side note, is
it safe to delete all previous version folders? They seem to be rather
large..
Thank You,
Brad Ebright
MGS Inc.
178 Muddy Creek Church Rd.
Denver, PA 17517
(717)336-7528
_____
mmcwilliams22
Sent: Thursday, October 21, 2010 11:17 AM
Subject: [Vantage] Re: Customizations Not Taking Affect
Yes it is safe to clear the client cache. This is where the client
caches the base form XML and any customizations. The first time you
open a form you see Vantage showing some popups with something like
"downloading base form", etc. The data its fetching is stored as XML
files in this cache directory structure. The next time you open the
form, Vantage client checks to see if anything has changed, and it if
hasn't it uses the local cache which is considerably faster.
-brian
Of Brad Ebright
Sent: Thursday, October 21, 2010 11:32 AM
Subject: RE: [Vantage] Re: Customizations Not Taking Affect
deleting
is
large..
Thank You,
Brad Ebright
MGS Inc.
Denver, PA 17517
(717)336-7528
_____
Of
mmcwilliams22
have
effect
so
When we
except
