Thanks Todd for your information - I just signed up for the Midwest Users
Meeting that will provide basic Report Builder training, which should,
hopefully, get me started.
> From: Todd Caughey[SMTP:caugheyt@...]
> Reply To: vantage@egroups.com
> Sent: Tuesday, October 31, 2000 4:53 PM
> To: 'vantage@egroups.com'
> Subject: RE: [Vantage] Customize Job Traveler/Copy Database
> Rick,
> We have extensively modified the traveler using Crystal Reports (V8). I
> would highly recommend getting the Professional version for a few extra
> dollars. Epicor has a good training class (register early, it fills up)
> which would be critical if you do not have a lot of reporting experience.
> I
> have used MS-Access for many years as well as other report builders and
> even
> so Crystal is so powerful and slightly different from others I needed
> training to appreciate and use even a fraction of what it has. You might
> be
> able to use the Financial Report Writer as a gauge of your skill level
> relative to Crystal. If you struggle at all with FRW you will have real
> difficulty with Crystal. Ditto for Progress Report Builder.
> Once you have Crystal in house I have posted a modified Traveler and
> Shipping Advisor in the download area which my give you some ideas for
> what
> can be done. I think the Ship Advisor requires the report distribution
> feature in the Professional version.
> As for 3.0 to 4.0 - sorry we started on 4.0 so never converted.
> Good Luck,
> -Todd Caughey
> Harvey Vogel Mfg. Co.
> -----Original Message-----
> From: Ludwig, Rick [mailto:RickL@...]
> Sent: Tuesday, October 31, 2000 1:30 PM
> Subject: [Vantage] Customize Job Traveler/Copy Database
> Hello-
> I've got a couple of simple questions for all of your Vantage experts!
> First, as we gear up to implement Vantage, we would like to customize the
> Job Traveler to fit our current traveler. Our president said we would
> need
> to obtain "Crystal Forms" in order to do this? Is this correct, how do I
> obtain it, and how complicated is it? (relatively speaking for an
> accountant!) Second, we need to copy our 3.0 database to 4.0 (we
> currently
> only use 3.0 for accounting purposes only - G/L & A/P) - it was copied for
> us back in the spring by someone else, but I was not shown how!. How do I
> go about doing this? Any help would be appreciated!
> Thanks in advance!
> Rick Ludwig
> Corporate Controller
> Metal Spinners, Inc.
> Angola, IN 46703
> (219) 665-2192 x225
> eGroups Sponsor
> <http://click.egroups.com/1/9642/13/_/411782/_/973020630/>
> <http://adimg.egroups.com/img/9642/13/_/411782/_/973020630/TargetInvestmen
> ts
> 468x602F.gif>
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> <http://www.egroups.com/files/vantage/>
> (Note: If this link does not work for you the first time you try it, go
> to
> www.egroups.com, login and be sure to save your password, choose My
> Groups,
> choose Vantage, then choose Files. If you save the password, the link
> above
> will work the next time you try it.)
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
