Go into the Data tools & create a Foreign Key View.
Use OrderDtl As the Table & then link using PartNum.
You can then use that new view to display netweight.
--- In vantage@yahoogroups.com, "gmack110256" <genemack@...> wrote:
> I am trying to get the part weight to show up on the UI SalesOrderForm. On the UI PartForm they show up listed as Net Weight under the "Part" data object. When I try to modify the UI SalesOrderForm the "Part" data object is not available to choose from so I can get to the "NetWeight".
> Is there a way to add the "Part" data object to the SalesOrderForm list of available objects?
> The "OrderDtl" data object is available on the SalesOrderForm but does not contain "NetWeight" as a part of it. Is there any way to add the "NetWeight" to the "OrderDtl" data object?
> If I can either add the "NetWeight" to the "OrderDtl" data object or add the "Part" data object to the SalesOrderForm I think I can get the information to show up like I want.
> Thank You for any suggestions
> Gene Mack
> Johnson Systems
