Dan,
Try changing your filter: "(LaborHed.ClockInDate = 09/27/00 OR
LaborHed.ClockInDate = ?)".
The join will cause EmpBasic records without a matching LaborHed record to
report the ClockInDate as ?, which fails your first filter (ClockInDate >
9/27/00).
Steve Sanders
Delta Centrifugal Corp.
dans@...]
Sent: Wednesday, October 04, 2000 8:52 AM
To: '
vantage@egroups.com'
Subject: [Vantage] daily attendance Report builder
I am trying to write a report showing daily attendance in report builder.
I
want to include employees who are absent. I joined laborhead to empbasic
using a left join. The left join is being cancelled out by my filter
laborhead clockindate > 09/27/00. Absent active employees are being
excluded. I sure the solution is obvious. Unfortunately the coffee has not
kicked in yet. Any help would be appreciated.
Dan Shallbetter
States Electric Mfg.
please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
