I’m trying to create a dashboard that filters using “BEGINS”.
I added the “Begins” filter to the grid properties which works just as you’d expect; however, once I deploy the dashboard I get the following error and all of my filters seem to not work.
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: Specified cast is not valid.
Program: Ice.Lib.EpiClientLib.dll
Method: NotifyAllOthers
Client Stack Trace
at Ice.Lib.Framework.EpiTransaction.NotifyAllOthers(EpiDataView sourceView, Boolean changeGridPropsCurrentRowOnly, Boolean notifyTree, Guid notifyId)
at Ice.Lib.Framework.EpiDataView.InnerNotify(EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.SetCurrentRow(Int32 newRow, Boolean currentRowOnly)
at Ice.Lib.Framework.EpiUltraGrid.OnBeforeCellActivated(Object sender, CancelableCellEventArgs ea)
I removed the begins filter from the grid and the error went away.
I also found that when I use “BEGINS” as a filter on the query itself it doesn’t error out but it goes too slow.
Has anyone else ran into this issue?
