Dashboard Chrome developer tools stopped working
Curious if anyone else has seen this, have been working on a dashboard that was converted over to Kinetic-Web and testing some changes that I made after.
Developer tools and ctrl-alt-8, ctrl-alt-9 (etc) were working fine, suddenly I can no longer active the logging to the console.
I’ve tried other dashboards, it works fine in those cases,
Looking for any ideas,
You try closing the browser and starting over?
Yep, exited all of chrome, cleared cache, to no avail
Even tried MS-Edge, no luck,
You can type this into the console… CTRL-ALT-8 (I think) was the keyboard shortcut to do this.
epDebug.toggleMetaFxLogging
What did CTRL-ALT-9 do?
Awesome, that worked, anyone know the similiar for ctrl-alt-9 and ctrl-alt-v
(those are the 3 I most commonly use)
What did those commands do?
oh, I see just typing epDebug. in the console window shows context sensitive help, I think I can figure it out from there
ctrl-alt-v is to “show data views”
ctrl-alt-9 is “event service debug logging service”
epDebug.views
Not sure about the other.
I found ctrl-alt-9 is epDebug.toggleCoreLogging
thanks !
If you start typing epDebug. into the console, a scrollable list appears of various options:
ALSO… if you use the same commands a lot… if you just put your cursor in the consol and hit the up arrow, it scrolls through recently used commands.
I don’t know the keyboard shortcuts because I typed them in once and now just use the arrow to toggle through to the one I want/need and hit “enter”.
