Dashboard Conversion: Classic --> Kinetic
From what I have read on here, converting dashboards is not fun for anyone involved. However I wanted to ask to see if there’s any to convert tracker views from classic to Kinetic.
For instance, I would like these fields that I have set up below in my tracker view to still convert over. In this possible yet in 2025 Epicor?
There is a way, but you have to fight for it:
And there are other ways… My current preferred route is to start from scratch with a new dashboard in Application Studio - especially with only a few fields in the Tracker.
Thank you! I will try to “fight for it” :rofl:and if I get stuck I will go your route.
Also, pro tip, for ranges, it’s easier to just duplicate the field by using a calculated field, then filter by that duplicated field in the second filter. Then only show the original field in the grid. The users won’t see a difference, and you don’t have to do any goofy double binding crap.
We have done it as shown above. Both are linked to TransView fields as TransView.From and TransView.To. These fields are manadatory and then used on the WhereList of BAQ options. It works very well for us.
