Dashboard Grid View, can a filter have a wildcard?
Thanks Charles.
So what I'm after can only be done with a tracker view and not a
grid ?.
--- In vantage@yahoogroups.com, "Charles Carden" <shadowcar1449@...>
wrote:
> Yes it can. Edit the dashboard tracker view. From customization
highlight the field that you want filtered. On the Dashboard
Condition select "Matches". The Matches works the same as it does
with a Quick Search, i.e. use an "*" as the wildcard character.
> From: clive.1972
> To: vantage@yahoogroups.com
> Sent: Thursday, October 09, 2008 3:24 AM
> Subject: [Vantage] Dashboard Grid View, can a filter have a
wildcard ?
> (Vantage 8.03.404)
> Pretty much as the subject says realy, I've tried '*' and '?' as
well
> just incase but neither appear to act as a wildcard, is this even
> possible on a dashboard's filter ?.
> Thanks.
(Vantage 8.03.404)
Pretty much as the subject says realy, I've tried '*' and '?' as well
Thanks.
Yes it can. Edit the dashboard tracker view. From customization highlight the field that you want filtered. On the Dashboard Condition select "Matches". The Matches works the same as it does with a Quick Search, i.e. use an "*" as the wildcard character.
Subject: [Vantage] Dashboard Grid View, can a filter have a wildcard ?
(Vantage 8.03.404)
Thanks.
