Yes not a problem in the BAQ but BAQ is being used in a lot of other places and so I shouldn't put any sort order on it. I need to achieve this in the dashboard...
Thanks!
Thanks!
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Can't you add a two-level sort in the BAQ?
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
> Of unackvi
> Sent: Thursday, March 19, 2009 3:39 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Dashboard - multiple SORTs?
> I have a BAQ based for Invoicing that will be used in a dashboard and in
> a report too.
> For the dashboard I need to have two SORTs i.e. by State and then by
> Invoice Num. I am not sure how to achieve both at the same time. When I
> click on the 'State' column heading I see the SORT is applied but if I
> also want SORT on the Invoice Num while it is already sorted on the
> State, how do I do that?
> Thanks for the help!
