Dashboard parameters with multiple BAQs
Hello,
I have a dashboard with 3 BAQs, they each use the same parameters. How can I avoid the user entering the same set of parameters 3 times?
Thank you
Larry
As far as I’m aware, at least for Epicor 9, there isn’t a way of doing that. One thing I’ve found that can sort of work though is publishing the fields on the first dashboard that are used in the parameters. Then you use those published fields to equal their respective fields in the other dashboards on the other dashboards filter criteria. The only problem with this method though is that it won’t work if your criteria doesn’t find anything in the first dashboard. It might also refresh the second two dashboards every time you select a new record in the first dashboard.
Thanks Kevin. I’ll give that a try.
