Lol - I only read 30% of any given posts in no particular order apparently
So what function/event is triggering your code?
I have it in InitializeCustomCode()
Perhaps you could add an event to the grid for InitializeLayout. Not sure, I’d have to play with it.
A possibility is that some underlying code it setting the formatting of that grid.You could easily test that theory by adding a grid as a custom control and seeing if it behaves any differently.
I think something related to grouping might be screwing it up? I notice that when things are un-grouped I can resize each row individually but when things are grouped resizing one row resizes them all…
Yeah, I added a button and put the code in the click event. It does what I want.
How would I go about making it so that my code runs after the data loads? I tried Form load and InitializeLayout for the grid but neither had the desired result.
Perhaps try an InitializeLayout event. Put this in your Initialize code (change the ref as needed)
yourGridRef.InitializeLayout += (o,e) =>
var sender = (EpiUltraGrid)o;
sender.DisplayLayout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.AutoFree;
//etc, rest of code here
That worked! - must be I set up the InitializeLayout event wrong the first time or didn’t reload the customization correctly. (Unless using an inline function makes a difference…?)
Big thanks
The inline wouldnt matter so much as having to explicitly create the event since you cant use the wizard on a native control. Glad it worked!
Hi all,
I have followed all the steps described, but the event for initializeLayout just won’t trigger. I tried both inline function and separate function.
I think this person in this post also had the same problem.
Here is my code, the MessageBox for Event Triggered just won’t fire. Any ideas?
dayLoadGrid = (EpiUltraGrid) csm.GetNativeControlReference("236c8dfb-5f01-4403-b73e-d104d2eb92c9");
dayLoadGrid.DisplayLayout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.AutoFree;
dayLoadGrid.DisplayLayout.Override.CellMultiLine = Infragistics.Win.DefaultableBoolean.True;
foreach ( Infragistics.Win.UltraWinGrid.UltraGridRow row in dayLoadGrid.Rows.All)
row.PerformAutoSize();
dayLoadGrid.InitializeLayout += (o,e) =>
MessageBox.Show("Event triggered");
// dayLoadGrid.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.dayLoadGrid_InitializeLayout);
MessageBox.Show("InitializeCustomCode");
Yeah, that didn’t work reliably for me either. I ended up just using the load event instead, works fine for my purposes.
private void MainController_Load(object sender, EventArgs args)
Ice.Lib.Customization.PersonalizeCustomizeManager personalizeCustomizeManager = this.csm.PersonalizeCustomizeManager;
// myGrid
Ice.Lib.Framework.EpiUltraGrid local2 = ((Ice.Lib.Framework.EpiUltraGrid)(personalizeCustomizeManager.ControlsHT["a982c660-8da7-4c1a-a775-624d31758cb5"]));
local2.DisplayLayout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.AutoFree;
local2.DisplayLayout.Override.CellMultiLine = Infragistics.Win.DefaultableBoolean.True;
Would you mind posting a screen shot of the final results? I would like to see what the grid ends up looking like.
Hello Evan,
Have you tried this for the columns headers as well? Having the ability to have 2 lines per column would help reduce the width, and still having meaningfull column headers, instead of truncated ones…
Pierre
Shhh, don’t give them ideas. Besides I haven’t figured out how to get the “page setup” menu item to come back with this customization present.
That’s nice solution. I want to understand a little better before I try it. Basically you are setting the width via some method (properties, or code, or personalization or whatever) and the AutoFree command then sets the row height based on the text in the cell right?
Actually I just had the width set by dragging the columns in developer mode and saving it. Only the row height is being set from code. I bet you can set the column widths from code as well, but I didn’t have any need for them to dynamically change, paper stays the same size…
Otherwise yes, this is a very simple customization.
DisplayLayout.Override.RowSizingAutoMaxLines
can be used to set the max number of lines for the rows. Remember these are all just Infragistics controls in the background, so looking at the documentation for the infragistics UltraGrid can be helpful.var yourGridRef = (EpiUltraGrid)csm.GetNativeControlReference(“your guid here a9a…”);
