Hi
I have a dashboard that i am filtering between a ‘to / from’ date on the LaborDtl_PayrollDate. Currently in my BAQ i have added 2 calculated fields on this table field
- Calculated_To
- Calculated_From
When i filter between the dates, both Date Editor boxes set to the latest date in the returned dataset
I have also tried to Date Editors on the same LaborDetail_PayrolDate with a GreaterThanOrEqualTo and LessThanOrEqualTo but this changes both Editors to the same date when either editors are updated.
I need the Date Editors to maintain the filtered date upon the data return as its providing ambiguity on the search.
What is the better to set up this tracker to provide this? I can change whatever i need to make it work?
Thanks so much
Nacho
