Dashboards not updating at launch
Apologies if this is in another post and I missed it.
Since the update last weekend, several dashboards that have filters on the data, do not apply the filters at launch, and only after closing and opening the window, or refresh does it apply the filtering.
I’ve attached an example - the bottom right corner shows all late jobs. Upon launch, it shows many jobs which is incorrect. Open and closing then displays the correct data.
What version are you on?
I actually just ran into a similar problem with a dashboard that was generated from a classic one. The criteria doesn’t want to apply unless you refresh the page. I fixed it by creating a button and binding refreshall event to the onclick event for the button. You may have luck trying to copy the onload and binding refreshall there?
Yes, we’ve seen this issue as well and our case is attached to PRB0319252 which was supposed to be fixed in 26.100.6 so maybe there is more to go. Suggest logging a ticket with this issue and let us know the case. I can ask to link my case to yours.
Thanks Randy. I’ll do that.
