Hello again,
Scratch that last request for help. I figured it out.
In case there's any interest in the solution, the problem was that I
added a column without making it part of a "named range" in Excel, so
the conversion tool could not see the column I added.
To name a range in Excel: highlight the range of cells, choose
Insert - Name - Define and type in a name for the range. You then need
to use that range name in the Source Query field on the Query Tab of
the Data Conversion Tool and voila...everything is hunky-dory...
Thanks for stopping by....
Darryl Whitelock
Dinn Brothers, Inc.
--- In vantage@yahoogroups.com, "Darryl Whitelock" <dwhitelock@d...>
Darryl Whitelock
Dinn Brothers, Inc.
wrote:
>data
> Hello everyone,
> I'm having a problem with the Epicor Data conversion tool. We are
> using Vantage 6.10.514.
> I set up an ODBC connection to an Excel spreadsheet that contains
> the data I want to import. I set up a connection and query in the
> conversion tool. I know it works properly because I can click thethe
> Results button on the Query tab and it shows up properly.
> Here's the problem: I wanted to add another field to import into
> Vantage. So I edit the spreadsheet, put in the column I want, name
> column, and put in the data that I want to exist in that field forResults.
> each record. I save the spreadsheet, open the data conversion tool,
> the proper connection and query. On the query page, I add the new
> column/field name into the Source Query Select box and click
> I get the column headings, but no data.means
> Now, according to the documentation I have, if that happens it
> there's a problem with the source data. Just for ha-ha's, I removethe
> new column/field name from the Source Query Select box, and clickcolumn
> Results. Sure enough, all the data shows up properly, minus the
> that I added in the spreadsheet (which really is what I wouldexpect).
> My first thought is there's something wrong with the column I added,like
> but it's formatted as text and I verified the column is formatted
> the other columns.
> From what little I've read about the data conversion tool in this
> newsgroup, it seems to be flaky. Hopefully some one here has had a
> similar problem and will be able to help out or have other
> suggestions.
> TIA and Happy Holidays!!
> Darryl Whitelock
> Dinn Brothers, Inc.
