We had a similar issue it is caused by the Codepage settings of the
database you are upgrading.
You need to convert the DB into utf-8 (Unicode) codepage.
The instructions for this were posted in the list :
Summary: How to convert your database to Unicode
Book: Support Solutions
Page: 6152MPS
PROBLEM DESCRIPTION: I would like to change my database from standard
iso8859-1 to Unicode, How do I do that.
PROBLEM RESOLUTION: Use the Steps below to convert your database to
Unicode.
Prerequisites:
A) You will need a Proword.2 file. This file can be found in your
\Epicor\Mfgsys80\Db\Newdb folder. If one is not there, have Tech Support
email one to you. Put the file into the \Epicor\oelOOb folder
B) WARNING: Before you start either process, have a good backup
of your database.
"%DLC%" is where OpenEdge is installed example E:\epicor\oelOOb
1) Go to Start --> Programs --> OpenEdge 10B --> proenv
2) Type: prompt <enter>
3) Change to the directory where the database exists and run the
following commands in the database while in the database directory.
4) To convert your database, type: proutil mfgsys -C convchar
convert UTF-8
5) Apply the new word-rules to the database, type: proutil mfgsys
-C word-rules 2
6) Next open the properties of the Progress/OpenEdge Data
Adminstration Tool:
Go to: Start --> Programs --> OpenEdge 10B --> Data Administration
tool, right mouse click and select Properties.
You will need to add a -rx switch to the target line of the Data
Administration tool.
example:
E:\epicor\OE100B\bin\prowin32.exe -p
Save the changes.
7) Now bring up the Start --> Programs --> OpenEdge 10B --> Data
Administration tool
Go to: Admin --> Load Data and Definitions --> Data Definitions (.df)
Load the "_tran.df" file located in your \Epicor\OelOOb\Prolang\utf
folder.
8) Finally, rebuild the indexes. Type the command:
proutil mfgsys -C idxbuild -TB 32 -TM 32 -cpinternal UTF-8 Answer "a"
for
ALL from the popup menu
Press "n" to the question: "Do you have enough disk space for index
sorting?"
9) Once the reindex is complete, make sure of the following:
- -> The Proword.2 file is in the \Epicor\OelOOb directory before you
restart.
- -> Verify in the \Epicor\OelOOb\Startup.pf <http://startup.pf/
<http://startup.pf/> > file
the correct code page is entered.
Bottom section of the Startup.pf <http://startup.pf/
<http://startup.pf/> > should look like:
- cpinternal utf-8
-cpstream utf-8
- cpcoll Basic -cpcase Basic -d mdy
-numsep 44
- numdec 46
10) Start the Database, login.
Of Tiffany McDonald
Sent: 10 January 2007 19:28
Subject: RE: [Vantage] Data Migration from V8.0 to V8.03.305
During the second phase it just kicks me out and appears to shut down.
"Paul V. Blais" <pblais@... <mailto:pblais%40lavignemfg.com>
Behalf
Of mcdonaldrichards
Sent: Wednesday, January 10, 2007 1:53 PM
Subject: [Vantage] Data Migration from V8.0 to V8.03.305
Has anyone done this migration? I've tried to do this according to
white paper provide by Epicor but I still can't get the 'schema change'
to run.
Page: 6152MPS
Unicode.
Prerequisites:
of your database.
convert UTF-8
-C word-rules 2
Adminstration Tool:
example:
Save the changes.
Administration tool
folder.
for
sorting?"
restart.
- cpinternal utf-8
-cpstream utf-8
-numsep 44
- numdec 46
Of Tiffany McDonald
> wrote: What error to you get?From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Behalf
Of mcdonaldrichards
to run.
