DataView condition expression
Hi,
Can anyone help with this. In DataView condition i want to compare two values Available_Users.LaborHed_EmployeeNum <> PmIdHolder.Team1PM. it is not working and probably because first value is a string and second is a number. How to write this condition properly, cast some how or what?
Read through this thread. @hmwillett explains creating a function to do this kind of thing. That way you call the function to do the conversion when comparing Strings and Integers.
But even with the function, there was some good troubleshooting in this thread to find a solution. Hopefully something in here should get you in the right direction.
Try this:
#_'{Available_Users.LaborHed_EmployeeNum}' != '{PmIdHolder.Team1PM}'_#
i get this in console Errors: invalid argument outside of criteria: 415,invalid token: !,invalid argument outside of criteria: 173
Found that this works Available_Users.Selected = True AND {Available_Users.LaborHed_EmployeeNum} <> PmIdHolder.Team1PM. But then the issue is why if i select one record then it is ok no itteration is called but if i select multiple records looks like the condition evaluates only first row for this {Available_Users.LaborHed_EmployeeNum} <> PmIdHolder.Team1PM and all rows for Available_Users.Selected = True so in this case when multiple records selected it bypasses second condition and all selected rows are stored in result dataview, I dont understand why this happening?
this worked Available_Users.Selected = True AND Available_Users.LaborHed_EmployeeNum <> β€˜{PmIdHolder.Team1PM}’. Thanks @hmwillett i was missing these fellas β€˜{}’ :slight_smile: . Thats a pain i have no clue when to use β€˜β€™ when != when <> when {} or etc. :confused:
Honestly, I really hate the dataview-condition widget.
It’s one of those where the syntax isn’t the same as everywhere else.
Like, take their tooltip for example:
Dataview.Column without curly braces (at minimum) or quotes.
Single equals sign, which to me means assignment, not equality.
Capital T on true when I’ve seen most of App Studio complain about that.
The use of AND when the other expression fields are using &&.
Hot. Mess.
