Date Values in BAQ Results via REST API
As of version 2023.1.6, I am seeing a change in the way dates are returned via the REST API, compared to past versions. It has broken our software integrations that rely on BAQs.
For example, I have a BAQ that I am running in versions 2022.2.12 and 2023.1.6. The BAQ returns at least one date field.
The actual date value from the database is ‘2023-05-17’.
Value Returned from BAQ via REST API
2022.2.12: “2023-05-17T00:00:00-05:00”
2023.1.6: “2023-05-16T19:00:00-05:00”
The above example is a Clock-In date from a Labor Header record. If I call the LaborSvc directly and retrieve a Labor Header record, the date values are the same in both versions.
This looks like some mis-handling of local/UTC times. Can anyone confirm that this is happening in your system as well?
We are about to upgrade to 2023.1.6 over the holiday weekend and this is a deal breaker. Not sure if I can remedy this. Any ideas?
It is a real bug. We tested it here.
If you can use the varchar and make it a date after that could be a workaround.
To be specific, you’ll have to read the thread, that statement quoted that I made was partially incorrect.
I got a call from Epicor Support. They are aware of the issue and development is researching it.
Currently only v2 of the REST API is affected, so a workaround would be to call v1 of the API.
This is OK for external integrations, but I’m not sure if API calls internally (like in App Studio) can be helped.
May be able to fudge it with a function call. :thinking:
If true then only mostly! The issue is that the API appears to be handling the variety of date/time datatypes with a one size fits all method that (incorrectly) casts values to a fully qualified datetimeoffset value. Any workaround that fudges the offset would likely not fix any values that shows up with an offset.
Not that BAQ technically allows datetimeoffset as a type now, but if the API continues to support timezone offsets after a fix then BAQ must support timezone offsets. Ideally API would stick as close as possible to the datatype it receives, because date/time type casts are :dumpster_fire: at the best of times much less running unattended on arbitrary BAQ’s.
Can confirm, this works! This will entirely avoid the API issue and won’t be broken by a bug fix. I have a couple of trello integrations that are extremely fortunately not broken right now, because I had some random premonition 2 years ago to handle converting datetimes to ISO 8601 string in BAQ’s.
