Hello everyone,
When we look up the stock report, “Include Non-Nettable Quantities” is unchecked by default. Bins that are set to Non-Nettable should also be included in the inventory check, so I always tell users to check this checkbox. However, users often print out reports without checking this by mistake.
How can I set the Default condition so that this checkbox is checked?
Thanks in advance!
Hi Pilio,
Users can make personalizations here on print dialog and save and then their defaults are saved, I believe. However across the board, you can do a customization using the form event wizard similar to below, where we default in a less than or = date for the scheduled shipments report.
Nancy
