I usually create a calculated field and concatenate the string values that I want together. I'm not sure how that will work with the calculated field in there, but it's worth a shot.
--- In vantage@yahoogroups.com, effgroups@... wrote:
> Hi all,
> I'm designing a dashboard for quotes and would like to know how can I set up a sort on multiple fields e.g. First customer then rating then dollar value etc.
> The problem is that since the amount field is taken from the quotedtl table and its a calculated field in the BAQ so I can't sort on it in the BAQ also if I sort on the dashboard it loses the customer sort
> Please help me out here
> Thanks
> Ephraim Feldman
