Epicor 9.05
Is there a way to clear/delete the entire list of rows that display for new suggestions in the planning workbench? The highlight range and pressing the delete only deletes the last record.
Epicor 9.05
Is this a onetime cleanup or something you want to happen each time the planning wb is opened?
Depending on how many, One time I would use a UD routine on update to clean them out or you can use spacebar to select the row and click the delete X to take them out.
If they were mistakes and the data has been fixed then running MRP in regen should clear them out.
Greg
