On Fri, Jul 24, 2015 at 11:41 AM, brenda mohr brenda@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Is there a reason you want them deleted? Instead of deleting, I tend to mark the row as no longer used via a checkbox and then just add checkbox == false. You can also zero/blank them out and/or overwrite them. I just think it is a bit safer.
Â
Brenda
Â
Sent: Friday, July 24, 2015 12:16 PM
Subject: [Vantage] Delete UD Table Records From Configurator E10Â
Â
Hi,
I'm writing out data from our configurators to be used when printing quotes and orders. Someone shared some nifty code to let me write my list to a UD table.
This is in a UD Method that will fire from the configurator on save event:
string ItemOrderKey = ItemOrder.ToString("000000");
using (var txScope = Erp.ErpContext.CreateDefaultTransactionScope()){Â Â Â var UD40 = (from row in Epicor.Data.WithExtension.With(Db.UD40, Epicor.Data.LockHint.UpdLock)Â Â Â Â where row.Company == Context.CompanyID && row.Key1 == InputName && row.Key2 == ItemOrderKey select row).FirstOrDefault();
   if (UD40 == null)   {     UD40 = new Ice.Tables.UD40();     Ice.IceDataContextExtensions.Insert(Db.UD40, UD40);     UD40.Company = Context.CompanyID;     UD40.Key1 = InputName;     UD40.Key1 = ItemOrderKey;   }   UD40.Character01 = ItemDescription;   UD40.Character02 = Character02;   UD40.Number01 = Number01;      Db.Validate();Â
What I need before this runs is to delete any rows existing from a prior configuration save.
Direction? Share some code?
JoeÂ
Joe D. Trent
Bigham Ag Equipment
Â
</div> <div style="color:#fff;min-height:0;"></div>
Hi,
using (var txScope = Erp.ErpContext.CreateDefaultTransactionScope()){ var UD40 = (from row in Epicor.Data.WithExtension.With(Db.UD40, Epicor.Data.LockHint.UpdLock) where row.Company == Context.CompanyID && row.Key1 == InputName && row.Key2 == ItemOrderKey select row).FirstOrDefault();
Joe
Joe D. Trent
Bigham Ag Equipment
Brenda
Hi,
Joe
Joe D. Trent
Bigham Ag Equipment
