Hi,
Is it safe to delete orphan records from ABTwork tables without testing?
BR
Hi,
BR
Looking at Data Dictionary Viewer it looks like this table is used by the Posting Engine during processing, so I would consult with Epicor Support to see if you can get a data fix to remove these orphan records. In general, it’s never safe to directly delete or modify records in the SQL database, and even data fixes provided by Support should be tested in a Test environment before being used in the Live database.
Thanks Smith
