Deleting Plant Blank Title 72961
Great suggestion to hide the Plants Tony! Worked great!! I
appreciate the advice.
-Sal
--- In vantage@yahoogroups.com, Tony Hughes <thughes281@...> wrote:
> First try to delete the warehouse, and if you get a similar error -
you cannot delete the plant.
> Note that also you'd have to delete any bins referencing that
warehouse. Plant>>Warehouse>>Bin
> And if there are part transactions referencing the Plant you can't
delete it.
> In this situation, if it's a matter of you just not wanting the
Plant to be visible, just go in to each user and remove their ability
to see the Plant (Company tab of User Edit)
> Tony
> From: idiabos <idiabos@...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, January 14, 2009 11:48:58 AM
> Subject: [Vantage] Deleting Plant
> Hello,
> I am attempting to delete a Plant but when I try I get an error
> message that says "Delete not allowed. Referenced by at least one
> warehouse.". Does anyone know where I can go to break this reference?
> Thanks!
> -Sal
Hello,
Thanks!
-Sal
Yes,
Â
This means there was transactions that took place in that warehouse. To delete the warehouse would meen that the records would have no reference to the deleted warehouse. I am not sure how to correct that or if you can, but if you have transactions in a record you cannot delete the record or warehouse in your case.
Â
Jonathan LangÂ
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Date: Wednesday, January 14, 2009, 11:48 AM
Hello,
Thanks!
-Sal
First try to delete the warehouse, and if you get a similar error - you cannot delete the plant.
Note that also you'd have to delete any bins referencing that warehouse. Plant>>Warehouse>>Bin
And if there are part transactions referencing the Plant you can't delete it.
In this situation, if it's a matter of you just not wanting the Plant to be visible, just go in to each user and remove their ability to see the Plant (Company tab of User Edit)
Tony
Hello,
Thanks!
-Sal
