Hi Martin,
You can pre-determine which printer a Crystal report goes to with some careful printer naming:
In the Crystal Reports Designer program, open your report, then go to the Print Setup option under the File menu. Choose the printer you'd like the report to go to, then re-save the report.
When run by a client, the report will print to your chosen printer IF:
- The name of the printer on the client machine is exactly the same as it's name on the machine that you just saved the report on. If this is not the case, you have some renaming to do!
If the printer on the client machine is named differently, the report will go to the client's default printer, whatever that may be, unless they manually change it's destination.
Does that make sense? Hope it helps :-)
++ Andy Watts
++ Ripley Engineering Ltd
++ Tel: 01256-473940
++ Fax: 01256-479991
++ mailto: andy@...
++ Andy Watts
++ mailto: andy@...
