Digest Number 11323
Is there a space in the users name?  That can cause problems.
So you would typically do the output to statement before the for each Loop and the close after the end.
Sent from my Verizon 4G LTE smartphone
-------- Original message --------
Date: 8/14/16 5:10 AM (GMT-05:00)
Subject: [Vantage] Digest Number 11323
5 Messages
Digest #11323
1a
Re: JobBoss and Epicor by "Charlie Smith" ctcharlie
3a
ABL OUTPUT TO by b_ordway
3b
Re: ABL OUTPUT TO by "Jose Gomez" jose_c_gomez
3c
Re: ABL OUTPUT TO by "Greg Payne" gpayne_e9
Messages
Sat Aug 13, 2016 6:21 am (PDT) . Posted by:
I have always converted Job Boss to Epicor, never the reverse. Hmmmm
Date: Fri, 12 Aug 2016 14:39:45 -0700
Subject: [Vantage] JobBoss and Epicor
Hello Group,
After a recent buy out of our company, the new owners have decided to move forward in replacing Epicor with JobBoss. Our shop currently is employing 250 employees and primary do make to order and production work for fabricating sheet metal.
This is less of a technical question, but more of a sales question, but I was hoping the group could provide a little feedback on their experience with a similar situation?
Regards,
--sf
Sat Aug 13, 2016 9:15 am (PDT) . Posted by:
p3zmcp
I am trying to modify our AP Check to show the GL allocations on the check.
For any one invoice - we may have 3 or 4 GL Allocations.
I added the APInvExp table to the DataDef and joined using Company, VendorNum, and InvoiceNum and used an outer join.
That appears to be working - I can see and print my APInvExp amounts.
However, I would like to display the GLAccount Description next to each of the amounts.
I thought I had this solved by joining the APInvExp to TranGLC and using Company, Key1 (VendorNum), Key2(APInvExp. InvoiceNum) , and Key3(APInvExp. InvoiceNum)
However I get an error when I try to join those fields.
So - I now see that there is an APInvExpTGLC table (I was unable to find this in the SQL Schema tables) and I thought I remembered that this table was added to help join to the TranGLC.
However - am at a loss to see how to make the joins.
Has anyone ever tacked the APInvExp to TranGLC?
DaveO
Ph: 651-246-3281
Feel free to call if the answer is lengthy.
Sat Aug 13, 2016 10:41 am (PDT) . Posted by:
b_ordway
Hi,
In V8.03 I have a BPM that is writing some data to a file in a users report folder
using a line like this: output to "D:\ epicor\ mfgsysdata&# 92;Reports&# 92;userxxx&# 92;PIF.txt" .
Was hoping I could send the output to a shared network folder but
When I tried a URL and mapping a drive, both of those attempts failed - the BPM throw an error & no output.
Bruce
Sat Aug 13, 2016 3:24 pm (PDT) . Posted by:
Did you try a UNC path?
On Saturday, August 13, 2016, bruce.d.ordway@... [vantage] <
vantage@yahoogroups.com> wrote:
> Hi,
> report folder
> using a line like this: output to "D:\epicor\mfgsysdata\Reports\userxxx\PIF.txt".
> Thanks
> Bruce
*Jose C Gomez*
*Software Engineer*
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
Sat Aug 13, 2016 9:29 pm (PDT) . Posted by:
I have a bpm that writes to a share that works on 9.05. I copied the lines from there and made a test on customer update that works in 905.702A.
Greg
define variable fileLocation as character init ''.
define variable outputLine as character init ''.
For Each ttCustomer where ttCustomer.rowmod = "U".
assign fileLocation = "\\svr-dapp\EpicorData\Reports\" + DCD-UserID + "\test.txt".
output to value(fileLocation).
outputLine = "stuff".
message outputLine.
End.
Sent: Saturday, August 13, 2016 1:42 PM
Subject: [Vantage] ABL OUTPUT TO
Hi,
Bruce
____________ _________ _________ __
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
"This (document/presentat ion) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
Useful links for the Yahoo!Groups Vantage Board are: ( Note:  You must have already linked your email address to a yahoo id to enable access. )
Yahoo! Groups
• Privacy • Unsubscribe • Terms of Use
_________________________________________________________________________________________________________
NOT INTENDED AS A SUBSTITUTE FOR A WRITING
NOTHING IN THIS E-MAIL, IN ANY E-MAIL THREAD OF WHICH IT MAY BE A PART, OR IN ANY ATTACHMENTS THERETO, SHALL CONSTITUTE A BINDING CONTRACT, OR ANY CONTRACTUAL OBLIGATION BY PNY, OR ANY INTENT TO ENTER INTO ANY BINDING OBLIGATIONS, NOTWITHSTANDING ANY ENACTMENT OF THE UNIFORM ELECTRONIC TRANSACTIONS ACT, THE FEDERAL E-SIGN ACT, OR ANY OTHER STATE OR FEDERAL LAW OF SIMILAR SUBSTANCE OR EFFECT. THIS EMAIL MESSAGE, ITS CONTENTS AND ATTACHMENTS ARE NOT INTENDED TO REPRESENT AN OFFER OR ACCEPTANCE OF AN OFFER TO ENTER INTO A CONTRACT. NOTHING IN THIS E-MAIL, IN ANY E-MAIL THREAD OF WHICH IT MAY BE A PART, OR IN ANY ATTACHMENTS THERETO SHALL ALTER THIS DISCLAIMER.
This e-mail message from PNY Technologies, Inc. (http://www.pny.com) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
