There are only 11 messages in this 25 message issue?
>>> <vantage@yahoogroups.com> 06/05/02 11:59AM >>>
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
There are 25 messages in this issue.
Topics in this digest:
1. RE: AP CHECKPRINT QUESTION
jleonard@...>
2. Re: PROBLEM WITH PRINTING CHECKS TO VENDORS
wmc20@...>
3. RE: [Off Topic] - New Server AND Back Up
caugheyt@...>
4. RE: [Off Topic] - New Server AND Back Up
jleonard@...>
5. Vantage Documentation
jhouse@...>
6. RE: Vantage Documentation
bkula@...>
7. RE: [Off Topic] - New Server AND Back Up
jleonard@...>
8. RE: [Off Topic] - New Server AND Back Up
tanderson@...>
9. Sometimes ya just gotta laugh/scream...
rgors@...>
10. RE: Disaster recovery
Malcolm@...>
11. RE: [Off Topic] - New Server AND Back Up
cgitzlaff@...>
12. New Server
rlunsf@...>
13. RE: Disaster recovery
jleonard@...>
14. RE: [Off Topic] - New Server AND Back Up
tanderson@...>
15. Re: [Off Topic] - New Server AND Back Up
rgors@...>
16. RE: [Off Topic] - New Server AND Back Up
jleonard@...>
17. RE: Vantage Documentation
tanderson@...>
18. Re:Vantage Documentation
MLowe@...>
19. RE: Vantage Documentation
jleonard@...>
20. RE: [Off Topic] - New Server AND Back Up
tjacobs@...>
21. RE: [Off Topic] - New Server AND Back Up
jleonard@...>
22. RE: Vantage Documentation
tjacobs@...>
23. RE: [Off Topic] - New Server AND Back Up
tanderson@...>
24. RE: AP CHECKPRINT QUESTION
karen.brodniak@...>
25. RE: [Off Topic] - New Server AND Back Up
wmc20@...>
________________________________________________________________________
Message: 1
Date: Wed, 5 Jun 2002 13:07:42 -0500
jleonard@...>
Subject: RE: AP CHECKPRINT QUESTION
I had the same problem. Our error was "Foreign Database Cursor Not Found".
This happens when there are a large number of AP Checks. There is no fix
for this. The only solution Epicor gave me was to print smaller batches.
From what I remember, the error is caused by Vantage referencing the Foreign
languages section of the database and doing it efficiently. Progress will
allow so many errors as the database gets bottlenecked and then you get the
error.
Sorry I couldn't be more help.
Jeremy Leonard
karen.brodniak@...]
Sent: Wednesday, June 05, 2002 11:40 AM
To: Vantage Group (E-mail)
Subject: [Vantage] AP CHECKPRINT QUESTION
Leonard,
I have been using a Crystal custom AP check that prints the invoice numbers
on both stubs-one for us and one for the vendor. This was working fine until
a large number of checks were set to be printed. A Crystal error came up
(user did not write the error message down) and checks did not print
correctly. Any ideas as to why this happened? Thanks for your help.
Karen Brodniak
Accounting Manager
Phone: 425-742-7011 x44
Fax: 425-353-8945
karen.brodniak@...
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Message: 2
Date: Wed, 05 Jun 2002 14:08:30 -0400
wmc20@...>
Subject: Re: PROBLEM WITH PRINTING CHECKS TO VENDORS
At 09:51 AM 6/5/2002 -0400, you wrote:
>computer upgraded since the last check run. Now when we tried to print
>checks, the spacing seems messed up and the font size seems to be
>off. Does anyone know how to adjust this?
Probably due to different print drivers. Are you using the OEM driver, or
the one that comes with windows? I'd try downloading the current driver
from the printer manufacturer and using it. There may also be settings in
the print driver's properties, like "download fonts" or "print fonts at
bitmaps" that you could experiment with.
If you really need to adjust the form, you need Crystal Reports to modify
the layout of Epicor's standard form.
>Looking at the help it appears you have to adjust fonts within Progress.
That's outdated info. Prior to Vantage 4, the check print was a Progress
routine. There were some .INI file things you could tweak then.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
Message: 3
Date: Wed, 5 Jun 2002 13:16:14 -0500
caugheyt@...>
Subject: RE: [Off Topic] - New Server AND Back Up
On our Vantage server (IBM Netfinitiy 5500) the "data" drive is really two
disks mirrored. We also have a warm spare for automatic roll over if either
side of the mirror fails. The RAID controller will build the warm spare
from the "good" side of the mirror set. I can then pop out the hot swapable
failed drive and replace it on the fly to become the new "warm" spare. I
did not mirror the system disk but now think I maybe should have. Also, in
the system are dual power supplies that share the load but either is big
enough to take over on own if one fails. These too are hot swapable.
Finally memory is in multiple modules in case one fails we can limp until
replacement (not hot swapable). Whole system is backed up with Veritas
BackupExec with emergency reload disks.
On topic of tape versus disk backup. I do copy Vantage backup to disk on
another server but nightly DLT tape goes off-site (my house) once a week as
well as nightly tapes going into a fireproof cabinet located in an
underground tunnel. Our auditors demanded off-site storage of backup.
-Todd C.
pjw@...]
Sent: Wednesday, June 05, 2002 12:31 PM
To: '
vantage@yahoogroups.com'
Subject: RE: [Vantage] [Off Topic] - New Server AND Back Up
I believe RAID 1, mirrored drives is the preferred configuration from
progress.
Patrick
dhieber@...]
Sent: Wednesday, June 05, 2002 11:52 AM
To:
Subject: Re: [Vantage] [Off Topic] - New Server AND Back Up
Patrick,
Will Vantage Run on Raid 1.
Dina
"Winter, Patrick" wrote:
> You are in a wonderful position. Hardware today such as disk drives and
RAM
> are very affordable for requirements of your size.
> My random thoughts for what they are worth:
> 1 processor. (megahertz is not the bottle neck anymore, go for price)
> 1 gb ram. (NT & Vantage take to RAM like a duck to water)
> 2 - 18gb Ultra SCSI drives, RAID 1
> 1 - 64mb PERC raid controller.
> (don't be afraid to spend more on drive speeds and controllers, it boils
> down to how fast you can get things from the hard drives to RAM, then
having
> enough RAM to keep it there.)
> 1 - 10/100/1000 NIC card. (You can get a 10/100/1000 8 port switch for
less
> than $500)
> redundant power supply, it's up to you how redundant you want to be.
> 20/40 DLT Tape Drive. (DLT are fast and friendly)
> Your in the $4000 to $6000 range. I favor Dell, but Brand Names is a
thread
> all by it's self.
> Patrick
> Remember: when you steal from once source, it's plagiarism; when you steal
> from several, it's research
> From: Dina Hieber [mailto:dhieber@...]
> Sent: Wednesday, June 05, 2002 10:47 AM
> To: vantage@yahoogroups.com
> Patrick,
> We are thinking about combining my file server and Vantage together. We
> currently have 5 datacollection stations and 8 full users.
> Our database is is 232 megs. It has taken two years to get to that.
> Thanks
> Dina
> > How many Vantage users do you have?
> > What is the size of your database?
> > What is your database growth rate per month?
> > Will you be running anything else on this server?
> > Patrick
> > Sent: Wednesday, June 05, 2002 9:54 AM
> > Subject: [Vantage] [Off Topic] - New Server AND Back Up
> > Hello Everyone,
> > I would like the groups suggestion - I was told today I could buy a new
> > server and Back Up Drive. Any suggestions for the server and for back
> > ups. I was told to buy something that would last and allow for growth.
> > Thanks,
> > Dina M. Hieber
> > Vamco International, Inc.
> > 555 Epsilon Drive
> > Pittsburgh, PA 15238
> > (412) 963-7100 - phone
> > (412) 963-9511 - fax
> > www.vamcointernational.com
> have
and
http://groups.yahoo.com/group/vantage/files/.>
http://groups.yahoo.com/group/vantage/messages>
http://groups.yahoo.com/group/vantage/links>
http://docs.yahoo.com/info/terms/ <
http://docs.yahoo.com/info/terms/>
and
> Dina M. Hieber
> 555 Epsilon Drive
have
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Dina M. Hieber
555 Epsilon Drive
Yahoo! Groups Sponsor
ADVERTISEMENT
http://rd.yahoo.com/M=226014.2032696.3508022.1829184/D=egroupweb/S=17050071
83:HM/A=1000239/R=0/*
http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1023298292%3eM=22
6014.2032696.3508022.1829184/D=egroupweb/S=1705007183:HM/A=1000239/R=1>
http://us.adserver.yahoo.com/l?M=226014.2032696.3508022.1829184/D=egroupmai
l/S=1705007183:HM/A=1000239/rand=320936156>
http://docs.yahoo.com/info/terms/> .
Message: 4
Date: Wed, 5 Jun 2002 13:18:07 -0500
jleonard@...>
Raid 1 will work fine, but I think RAID 10 is now the preferred
configuration for a Progress Database. Raid 10 is faster and you can add
more drives later but you pay for it. You loose 50% of your drive space to
raid. The only other drawback is that you have to have a RAID card that
supports RAID 10. There are many that do not.
Jeremy
pjw@...]
To: '
progress.
Patrick
dhieber@...]
To:
Patrick,
Dina
RAM
having
less
> than $500)
thread
> all by it's self.
> Patrick
> Patrick,
> Thanks
> Dina
> > Patrick
> > Hello Everyone,
> > Thanks,
> > Dina M. Hieber
> > 555 Epsilon Drive
> have
and
and
> Dina M. Hieber
> 555 Epsilon Drive
have
Dina M. Hieber
555 Epsilon Drive
Message: 5
Date: Wed, 05 Jun 2002 11:17:44 -0700
jhouse@...>
Subject: Vantage Documentation
Does anyone else feel like they are having there money sucked out of them
by Vantage?
I go to do an upgrade to 5.1 and after talking to Vantage I will need to buy pre-consulting
to prepare for the upgrade and then post consulting to make sure we have it running correctly and that
the new procedures are done correctly.
Five thousand dollars every time I upgrade? (of course this is on top of a $25,000.00 maintenance fee)
Oh you don't have to upgrade but if your down two rev. levels we don't support your software anymore.
Ooooo I am so upset!
Message: 6
Date: Wed, 5 Jun 2002 13:13:36 -0500
bkula@...>
Subject: RE: Vantage Documentation
I believe most people did not hire Epicor to do any pre-consulting on an
upgrade or any post consulting unless you have not run Vantage prior to the
5.1 installation.
jhouse@...]
Sent: Wednesday, June 05, 2002 1:18 PM
To:
Subject: [Vantage] Vantage Documentation
by Vantage?
pre-consulting
Message: 7
Date: Wed, 5 Jun 2002 13:22:51 -0500
jleonard@...>
I want an underground tunnel....
I'm sure it would be called the Nerdcave....
caugheyt@...]
Sent: Wednesday, June 05, 2002 1:16 PM
To: '
-Todd C.
pjw@...]
To: '
progress.
Patrick
dhieber@...]
To:
Patrick,
Dina
RAM
having
less
> than $500)
thread
> all by it's self.
> Patrick
> Patrick,
> Thanks
> Dina
> > Patrick
> > Hello Everyone,
> > Thanks,
> > Dina M. Hieber
> > 555 Epsilon Drive
> have
and
and
> Dina M. Hieber
> 555 Epsilon Drive
have
Dina M. Hieber
555 Epsilon Drive
ADVERTISEMENT
Message: 8
Date: Wed, 5 Jun 2002 13:13:17 -0500
tanderson@...>
Underground tunnel ... Hmmmm, you can store your backup tapes next to your
wine cellar.
In the case of a disaster you can just go down to the tunnel, open a bottle
of well aged Cabernet Sauvignon, and say to heck with it all ...
jleonard@...]
Sent: Wednesday, June 05, 2002 1:23 PM
To: '
caugheyt@...]
To: '
-Todd C.
pjw@...]
To: '
progress.
Patrick
dhieber@...]
To:
Patrick,
Dina
RAM
having
less
> than $500)
thread
> all by it's self.
> Patrick
> Patrick,
> Thanks
> Dina
> > Patrick
> > Hello Everyone,
> > Thanks,
> > Dina M. Hieber
> > 555 Epsilon Drive
> have
and
http://groups.yahoo.com/group/vantage/files/.> >
http://groups.yahoo.com/group/vantage/messages> >
http://groups.yahoo.com/group/vantage/links> >
http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/> >
and
> Dina M. Hieber
> 555 Epsilon Drive
have
Dina M. Hieber
555 Epsilon Drive
ADVERTISEMENT
http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1023298292%3eM=22>
http://docs.yahoo.com/info/terms/> > .
Message: 9
Date: Wed, 5 Jun 2002 14:30:34 -0400
rgors@...>
Subject: Sometimes ya just gotta laugh/scream...
Gang:
Okay. Here's my sad story.
When adding a new customer, at the point of selecting an appropriate FOB location (99% of the time, our own city), the S#@$ department would select ADD (!!). Yes they kept adding and using slight variations on the same thing. "RICH HILL"..."Rochester Hills, MI", or some other variation.
I have many, many loaded and of course locked out from deletion because zillions of orders reference one or another.
Is there any way, shape or form that someone has a little ditty that will change them all to one, correctly spelled FOB of my choosing. Ideally I could then delete all the extras.
(Yes I have secured all the little devils out now)
Thanks for any/all responses......
Rick Gors
MR/MMIS
Osco
Message: 10
Date: Wed, 5 Jun 2002 11:29:28 -0700
Malcolm@...>
Subject: RE: Disaster recovery
One last thing to think about:
A rapid rollover to a backup server is great, from the server standpoint.
However, from the client standpoint, *every* client in your building will
still be pointed to the old server. Unless you've already configured every
workstation to also point to the training (or backup) server, you'll have to
re-install the client on the workstations.
A message from the Department of Redundency Department
Malcolm Spann
MIS
Malmberg Engineering
Malcolm@...
> From: Leonard, Jeremy [mailto:jleonard@...]
> Sent: Wednesday, June 05, 2002 8:48 AM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] Disaster recovery
> We have several servers. We have one very high end dual P4
> 2.0Ghz PC that we use for our Vantage Training Server and our Development
> Server. If something would happen to our Vantage server, the test
server could be
> switched over to the live database very quickly. Since a total loss
> scenario is very rare, we have done a few things to make the
> loss of our Vantage server more survivable. We have a maintenance build
> on the same property but several hundred ft away that we ran fiber to.
> We have Vantage backups being sent there several times a day. We also
backup
<span title
