Disable Conversion Workbench step "Enable new Kinetic UIs"
We are moving from 10.2.700 to 2023.1. In my test environment, I’ve loaded our prod data into the database and upgraded it. I’m now at the point where I’m needing to run Conversion Workbench. However, when I ran it it converted all of my classic UI screens to Kinetic (even when I chose “modern” from the login options when logging in). I re-loaded the database, re-upgraded, and now I’m on conversion workbench again and I see the task “EnableKineticUI” but I can’t disable it. If I don’t run it, I can’t get past conversion workbench.
We don’t want Kinetic UI changes with the upgrade. That’s a separate project for post-upgrade. How do I disable this task so that I can move on and log in without being forced to move to Kinetic??
