Disable "same check" popup in AP Payment Tracker?
The popup below occurs when selecting particular checks in Payment Tracker. I have a request to disable the popup, but in Application Studio I don’t see a slideout for it, so I’m guessing there is an event which generates it, but out of the many dozens of events I can’t tell which one it might be. Or perhaps it is a BPM?
Any ideas how to track it down?
Awesome - thank you! I didn’t think Console would help me out, but I should have tried!
You need to turn on Debugging on the Console…
Also… I have to ask… Why are you trying to change this? If you have multiple payments just turning off the sldie out won’t fix the underlying problem.
It is a request from a senior person in Finance. They know what they’re doing, so they just consider the popup a nuisance.
Hey Folks,
Where is this AP payment tracker that you speak of? I am not seeing it in Kinetic browser 2025.1. We only have this and I don’t see any Kinetic program to replace it.
thanks,
Nancy
I’m not sure how it got on the menu - I don’t recall adding the UD menu entry - but here it is:
Thanks so much Tim!
Nancy
For those who ran into the same issue as me, not sure how to get this menu to show up, you can simply hit the + and add it to your menus. Just copy what Tim has listed above and save. From there you can search for the Payment Tracker report and it will properly launch.
