Dear Team,
I tried the disable the all controls in Landed cost tab in Receipt Entry. When we click the Receipt entry Received All is checked the Landed cost controls should be disable/readonly.
Dear Team,
How did you disable everything you wanted?
Most likely that is overriden by Extended Properties. Use the Extended Properties wizard perhaps.
yes @chaddb everyting need to be disabled. while Receipt Entry Header Received All checkbox is checked.
ok @Chris_Conn. But the Received All checkbox is base control. I tried the this way but not able to checked event is not fire.
