Disappearing Refresh All?
I'd be delighted to, if the properties were available...
A call to tech support told me the same thing, with the extra bit
about right-clicking on the left-hand pane to get the properties page.
Of course, the left-hand, white pane only appears in Developer mode,
and then the 'Properties' entry is unavailable until I try to 'Save
As..' from the File menu. So I wind up with a custom Dashboard that I
have to open separately each time, just to get the 'Refresh All'
button back where it belongs.
After going through all that, I did restore the button. Now, the
thing doesn't work. Whatever combination of buttons or search
parameters I use, including 'Select All', the best I can get is a
display of one record, which seems to run counter to the point of
having a 'Search Results', plural, pane in the first place. [And at
this point, Vantage's behavior has taken a sharp turn from what's
described in the Tools User Guide, which is where and why I started
this exercise in the first place.]
Stopping and restarting the appservers has no effect on this behavior,
either.
Right at the moment, I'm not feeling kindly disposed towards the
developers of this 'improvement'....
Lynn Thomas
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...>
wrote:
> You have to check the "Enable Refresh All" box on the properties for
> the Dashboard itself.
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@... ~ 734-864-5618 ~
> www.advancedphotonix.com
> Of Lynn Thomas 83
> Sent: Thursday, January 15, 2009 8:48 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Disappearing Refresh All?
> I'm implementing Vantage at the 405A level, and I just started digging
> into dashboards. Using the tools guide, I was merrily following an
> example when I discovered that, contrary to the screen shots in the
> book, I have no 'Refresh All' button on the dashboard. A quick look
> at a couple of others revealed the same absence there.
> If this works as it's advertised, it would be most useful to our
> managers. Did I miss something in the patch upgrade, or is there
> something I have to do first?
> TIA,
> Lynn Thomas
> SAIC
TIA,
Lynn Thomas
SAIC
Picometrix
Of Lynn Thomas 83
TIA,
Lynn Thomas
SAIC
