Can anyone tell me what steps are required to DMT alternate operations & BOM’s without affecting the current operations and BOM?
Mike
Mike
The Primary Alternate Method is set on the Part Plant tab, the field is PartPlant.AltMethod. This is probably an empty string if you have not used Alternate Methods before.
When loading alternate Operations and Materials with DMT, set the PartMtl.AltMethod and PartOpr.AtlMethod values to avoid updating the existing records.
Thanks for the response, we will look into it.
