Epicor Version 10.0.700.4
We are a new E10 install and we are wanting to DMT our Inventory for our parts, we have one company, one warehouse. Which DMT template is used to load our part Inventory QOH?
Once you log into DMT, under the Part pull down, look for Quantity Adjustment. Then from there you can create the template with the bottom right hand corner. Select the fields you need. Most mandatory fields will be checked for you already. I think the ReasonCode might not be checked, but that is because there is a system setting that will require that or not.
Sent: Friday, August 21, 2015 6:05 AM
Subject: [Vantage] DMT Help for Inventory QOH
