DMT help
Hi,
I’m trying to upload a Part Plant File into our system. However its coming up with the message Table: PartPlant Msg: Warehouse is required.
Does anyone have a suggestion where i could start with that? Is is that the warehouse isn’t correctly set up?
many thanks
Y
Make sure the “PrimWhse” is populated with the primary warehouse in the site you are importing for. Yes, the warehouse also has to be setup and valid in the site before you can import.
Was in the middle of replying with another long winded message… could not have said it any more succinctly… Thanks :slight_smile:
