DMT issues
We are trying to load our company data with DMT in the Kinetic version. When we try to load our data over we keep getting an error about our Company can not be changed. We only have one Company. Any suggestions would be greatly appreciated!
Do you have any screenshots or error logs you can post?
At some point the Company field in the DMT became case-sensitive. Make sure that however the record is in the database, the DMT file matches exactly.
I guess this is matching issue with what you have in database. Try to copy exactly what you have in database. Also make sure all the mandatory fields are included.
