Dmt - openload ar - salesreplist
Has anyone ever tried to DMT the SalesRepList in the OPENLOAD AR table?
I know it’s a “special” field in that it’s “~” delimited
But even without multiple values - i’m not seeing the field update.
TIA
From the DMT Template builder:
(Sorry I couldn’t just copy the text)
@ckrusen yes - I’ve seen the note. but then again, I shouldn’t be able to update a posted invoice either - but I can :slight_smile:
anyway - the only way I’ve been able to do to get this to work is to use the AR HEADER DMT on a separate run.
which does show the SR’s separately. I suppose it is what must be.
thanks
