DMT part to flag serial tracking
Hi,
I’m trying to flag a number of parts to be serial tracked. I can do it manually, so there is no issue with that. However when I try to import the list of parts, it won’t allow it. It gives me the error message a serial number format must be defined, but there’s no fields in DMT either for Part or PartCombined to allow me to do that.
Has anyone had a similar issue?
Jonathan
Hi,
I actually worked this out myself. If anyone else needs help on it, then drop me a message :slight_smile:
Jonathan
Feel free to post your solution. The point of the forum is to share our experiences with others so people in the future can benefit. Dead threads like this become candidates to be deleted by the admins if they provide no value to the community.
Hi Mark,
Point taken.
There is a column heading which needs to be added to the Part DMT import file called SNBaseDataType. I used the value “CHARACTER” which set the serial number format to Alphanumeric - a surprisingly simple solution!
